Argon
Sep 14, 2021Aspirant
No Option to disable 5 ghz under Advanced Wireless Setting
After spending some time trying to connect my TP Link Smart Plug to my new Mesh set up, I googled the issue. Eventually i found where I login to my Orbi network via my mac. I went to the Advanced...
Argon
CrimpOn - when you say use the iphone app - are you referring to the Kasa app for the TP Link Plugs?
CrimpOn
Sep 14, 2021Guru - Experienced User
Absolutely. The smartphone app for TP-Lonk's Internet of Things (IoT) products is KASA.
I use the Android version (having no fruit devices - pun)
- ArgonSep 14, 2021Aspirant
Thank you, CrimpOn - that worked - although I am not sure how. If I go to the Alexa App - I had 3 of 4 attempts before Alexa saw the plug - Alexa says Device Unresponsive. However if I say turn on or off the Light it works. As you might guess....I am not a Millenial.
I really appreciate the assist!
- FURRYe38Sep 14, 2021Guru - Experienced User
Enjoy.- ArgonSep 15, 2021Aspirant
Thank you, Furry. I did the download and placed moved it to location where I can find it again. I take it that I do not need to open it - just have it in case I lose the setup? I saw the option where I would reinstate the back up.
