Argon
Sep 14, 2021Aspirant
No Option to disable 5 ghz under Advanced Wireless Setting
After spending some time trying to connect my TP Link Smart Plug to my new Mesh set up, I googled the issue. Eventually i found where I login to my Orbi network via my mac. I went to the Advanced...
Argon
Sep 15, 2021Aspirant
Thank you, Furry. I did the download and placed moved it to location where I can find it again. I take it that I do not need to open it - just have it in case I lose the setup? I saw the option where I would reinstate the back up.
Sep 15, 2021Guru - Experienced User
Correct.
