BjoernKW
Dec 23, 2020Aspirant
No Orbi RBR50 firmware update (from V2.5.2.4) available
Today, I received an email from Netgear stating that a new router firmware version is available for Orbi RBR50 routers. However, both the iOS app and the "Firmware Update" section in the web admi...
BjoernKW
vajim wrote:
John_Ba wrote:
Had the same and no update, UKWhat should that tell you?
How are we supposed to know? Perhaps that Netgear's update servers aren't working right now?
- vajimDec 23, 2020Master
BjoernKW wrote:
or....ask yourself this question...."is my network performing as it should?"
If so, perhaps you don't need a update.
- BjoernKWDec 23, 2020Aspirant
The email by Netgear explicitly mentions an important security update.
This reply isn't just not helpful but actually harmful because it brushes off security concerns.
BjoernKW wrote:The email by Netgear explicitly mentions an important security update.
Wonderful.....then I suggest you jump on it and keep the 'harmful' comments to yourself. In the meantime, the suggestion is to do a search in here and read the number of those who updated only to find problems and ended up reverting back. Please read the release notes and make your own decisions.
This reply isn't just not helpful but actually harmful because it brushes off unnecssary firmware update concerns.
There are others like you that like to sniff out firmware updates and I'm sure they will chime in here soon. So join them and I wish you the best.
