BjoernKW
Dec 23, 2020Aspirant
No Orbi RBR50 firmware update (from V2.5.2.4) available
Today, I received an email from Netgear stating that a new router firmware version is available for Orbi RBR50 routers. However, both the iOS app and the "Firmware Update" section in the web admi...
vajim
Dec 23, 2020Master
FURRYe38 wrote:
If your system is working, you don't have to necessarily update.
good advice from one of the smartest here on this forum
Bing-Stroller
Dec 23, 2020Luminary
So, basically ignore the email from Netgear stating that a new router firmware version is available for Orbi RBR50 routers if yours is working OK.
Even though the Subject Line is "Important Security Firmware Update from NETGEAR"
- vajimDec 23, 2020Master
Even though the Subject Line is "Important Security Firmware Update from NETGEAR"Basically...what I support is making up your mind. Never used the word 'ignore'.
Advice in forums is like a box of chocolates, you'll never what you get.
- Bing-StrollerDec 23, 2020LuminaryAdvice in forums is like a box of chocolates, you'll never what you get.
You have lost me there 🤔- vajimDec 23, 2020Master
You have lost me there 🤔I love typing
Advice in forums is like a box of chocolates, you never know what you'll get.
- FURRYe38Dec 23, 2020Guru - Experienced User
It's up to you if you want to update, or not.
Your choice.
Even though the Subject Line is "Important Security Firmware Update from NETGEAR"- vajimDec 24, 2020Master
Or you could simply say that it's up to you if you want to update, or not.
