Famke
Aug 14, 2019Aspirant
No orbi wifi but still wifi
hello, we bought orbi rbr20 to help our nighthawk to get wifi around the house. We were not be able to download apps with IOS. I had contact with the support and they told me to change the nighthawk router to bridge/pass-through mode. I have don this and this did not work. Then they gave me the advise to change the orbi to Acces Point mode. Here is my problem, i do not get on the orbilogin with any of my devices. I get the message that i am not connected with orbi wifi but i am still using the same wifi for this message so im connected. What is wrong? Can somebody please help me.
Greetings
What is the model # of the Nighthawk router?Use a wired Pc connected to the back of the RBR and connect to the RBRs web page using a web browser here...
Famke wrote:hello, we bought orbi rbr20 to help our nighthawk to get wifi around the house. We were not be able to download apps with IOS. I had contact with the support and they told me to change the nighthawk router to bridge/pass-through mode. I have don this and this did not work. Then they gave me the advise to change the orbi to Acces Point mode. Here is my problem, i do not get on the orbilogin with any of my devices. I get the message that i am not connected with orbi wifi but i am still using the same wifi for this message so im connected. What is wrong? Can somebody please help me.
Greetings
- ekhalilMaster
Famke wrote:........ i do not get on the orbilogin with any of my devices. I get the message that i am not connected with orbi wifi but i am still using the same wifi for this message so im connected. What is wrong? Can somebody please help me.
Greetings
- Do you have this issue using both wired and wireless devices?
- Use the command prompt from any computer attacged to Orbi to execute the command traceroute orbilogin.com. What do you get?
- From the Attached Devices in your Nighthawk router, what IP address does Orbi have? Will using this IP address work to access Orbi?
- FamkeAspirantthanks for answering. it looks like the problem has been resolved this night. I was probably impatient. 😏
Greetings
