Brighton71
Feb 13, 2021Aspirant
No parental controls tile in Orbi app???
Want to set up Smart Parental Controls on my Orbi system. All of the online documentation says that there should be a Parental Controls tile in the Orbi app. Mine doesn't have it. Also not in the rou...
Feb 13, 2021Guru - Experienced User
Plesae post about this over in the Circle forum:
Thank you.
- Brighton71Feb 13, 2021Aspirant
I checked that post. I don't get parental controls as an option in Attached Devices.
See below...
- FURRYe38Feb 13, 2021Guru - Experienced User
You'll need to contact NG support to help you out.
