Brighton71
Feb 13, 2021Aspirant
No parental controls tile in Orbi app???
Want to set up Smart Parental Controls on my Orbi system. All of the online documentation says that there should be a Parental Controls tile in the Orbi app. Mine doesn't have it. Also not in the rou...
Brighton71
I checked that post. I don't get parental controls as an option in Attached Devices.
See below...
Brighton71
- FURRYe38Feb 13, 2021Guru - Experienced User
You'll need to contact NG support to help you out.
- vajimFeb 13, 2021Master
FURRYe38 wrote:You'll need to contact NG support to help you out.
only IF you're still under warranty otherwise open wallet.
- MitechJun 15, 2021InitiateYeah, I talked to a tech in December, who said they were replacing Circle with their own product, and it would appear in the app within a few weeks. Based on that, I kept the routers. But obviously they lied.
I won't but Netgear again.
