changeway
Dec 24, 2019Aspirant
No Security 5G wifi in RBS40V when wired synced.
I connected the speaker to oribi router by wired connection. Router Wifi setting sync to the speaker, looks good. But I found only the 2.4G sync correctly. 5G SSID synced, but Security Type is ...
ekhalil
Dec 24, 2019Master
Seems that syncing of the RBS40V satellite to the router did not work.
I suggest to remove the satellite (switch off the satellite then from the web GUI >> attached devices, click on disconnect). Then do the satellite addition again.
changeway
Dec 25, 2019Aspirant
I tried several times, remove the speaker in Orbi router Web-GUI and then sync again. 2.4G wifi always good, but 5G wifi security is always None. Here are the version info:
- Hardware Version: RBS40V
- Firmware Version: V2.3.6.4_1.0.1
- ekhalilDec 25, 2019Master
changeway wrote:I tried several times, remove the speaker in Orbi router Web-GUI and then sync again. 2.4G wifi always good, but 5G wifi security is always None. ....
This seems very strange, must be something in the satellite's configuration. I suggest to factory reset the satellite (NOT the router) and then synch it again with the router..
