changeway
Dec 24, 2019Aspirant
No Security 5G wifi in RBS40V when wired synced.
I connected the speaker to oribi router by wired connection. Router Wifi setting sync to the speaker, looks good. But I found only the 2.4G sync correctly. 5G SSID synced, but Security Type is ...
changeway
Dec 25, 2019Aspirant
I tried several times, remove the speaker in Orbi router Web-GUI and then sync again. 2.4G wifi always good, but 5G wifi security is always None. Here are the version info:
- Hardware Version: RBS40V
- Firmware Version: V2.3.6.4_1.0.1
ekhalil
Dec 25, 2019Master
changeway wrote:I tried several times, remove the speaker in Orbi router Web-GUI and then sync again. 2.4G wifi always good, but 5G wifi security is always None. ....
This seems very strange, must be something in the satellite's configuration. I suggest to factory reset the satellite (NOT the router) and then synch it again with the router..
