avsprang
May 05, 2019Aspirant
no signal on lan ports
Hello, I configured RBR50 first in router mode and later as wireless accespoint. In both configuration I got no signal on the Lan ports. Wifi is working well but the Lan ethernet ports don't work. Ha...
schumaku
May 06, 2019Guru - Experienced User
avsprang wrote:
this is what the imac is telling me and still no internet
So the iMac does get an IP config, and we can assume the physical networking, the ports are OK.
You might have configured Access Control in whatever way, e.g. as lined out in the Orbi User Manual, p.56, with "Allow all new devices to connect" or "Block all new devices from connecting." - so you might have to allow the device. Be aware that "device" can vary - for the router it's not the same if connected by WiFi or by Ethernet, due to the different MAC addresses.
avsprang
May 06, 2019Aspirant
thanks, I will check out this option
