Mr_bwd
Jun 15, 2020Aspirant
No signal on my rbs40v
Sinds last year i have the orbi rbk 50 (rbs50 and rbr50). last month I bought the rbs40v voice as extension. The voice has been placed on the older rbs50 place and is often falling away in the connec...
Jun 16, 2020Guru - Experienced User
What firmware is the orbi voice on?
have you tried moving it further away or laterally? sometimes hvac or foil lined backing in floors can cause issues.
Have you tried it with daisy chaining enabled/disabled?
- Mr_bwdJun 16, 2020AspirantThe firmware of the voice is v2.5.1.2.
The firmware of the router and satellite is v2.5.1.16. I have tried to switch the satellite and te voice from places. The satellite is working fine but the voice is falling away.
I have tried the daisy chaining enabled and disabled.- plemansJun 16, 2020Guru - Experienced User
have you tried it hardwired in?
mabye you're having a hardware failure. Not sure how old it is but you could check with support if you're still within warranty.
click mynetgear at the top. Register an account and the device.
- Mr_bwdJun 18, 2020Aspirant
Hi Plemans,
What do you mean by hardwire? connected with cable?
Yes i have tried that but can't see that in the app. And the connection is not stable. after rebooting the whole system i can use the connection for a few hours and than must reboot the whole system again.
I bought the RBK50 in oct 19 and the voice in april 20
