peevee36's avatar
peevee36
No Spotify after Orbi upgrade (internetradio no problem)
Dear Community,   Best wishes for 2020. Last week I upgraded my network form Netgear R7000 nighthawk to Orbi RBK50. With the nighthawk everything worked fine except I didn't have enough Wifi cove...
  • tucsontico's avatar
    Jan 02, 2020
    Check your Denon to see if there is a firmware update. I have a Denon X3200W that had a similar loss of Pandora due to them changing the security signature on Pandora. Unfortunately, it required Denon to update the AVR firmware to solve that issue. Otherwise a power cycle of your Denon (unplug it for 30 sec and plug it back in) may recover Spotify.
    Good luck!
