Sanibel1
Jun 17, 2021Aspirant
No transmittion speed seen in Obi App
Hi all, inm y Orbi APP i don't see any longer the transmittion speed of my connected devices to the Satellites. All Systems are up to the latest Version of Firmware. And please don't tell me I ...
michaelkenward
Jun 18, 2021Guru - Experienced User
You have posted your message in the section of this community given over to General WiFi Routers (Non-Nighthawk). (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so there may be useful responses here. However, the Orbi is very different from a standard router, so you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- Sanibel1Jun 19, 2021Aspirant
??? What is the solution here please...
Your answer doesn't solve anything
Henry
- michaelkenwardJun 20, 2021Guru - Experienced User
Henry
You asked in the wrong place. People who understand the Orbi system don't hang out here.
I could also have added that your question needs a a better explanation. But I sense that this isn't the sort of thing that would come easy to you..
You should know that this community is essentially a user-to-user venue with some input from a small band of Netgear techies.
Most of the answers come from fellow users who have no connection with Netgear. They just have a lot of collective experience and are familiar with the sort of problems that turn up here.
If you want "official" support then you should go through the right channels.
Contact Us | Support | NETGEAR
