BmMdlk
Sep 12, 2022Tutor
No Valid IP address for multiple devices- comes and goes (RBR50 & 2 satellites)
This started a few months ago and has been getting progressively worse. Both wired and wireless devices randomly drop their connection with the error message no valid IP address. Power cycling the ro...
- Sep 13, 2022
Changing the address pool range seemed to fix things- at least for now, Thanks for that suggestion, I never would have thought of it!
I appreciate your help!
Sep 12, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How many devices do you have connected to the system?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- BmMdlkSep 12, 2022Tutor
V2.7.4.24
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?NETGEAR Cable Modem CM1000. I purchased and installed
I am using CAT6
How many devices do you have connected to the system? \
20-25. Usually only 3 or 4 used at a time
3,500
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS 100+ feet to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satelliteWhat channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Using auto and 48. Haven't tried other channels. Will test other channels.
Any Wifi Neighbors near by? If so, how many?No
yes
Turn on computers and rest of network.This has been done several times.
Yes
Thanks for the suggestions. Will try different channels
- FURRYe38Sep 12, 2022Guru - Experienced User
You might change the default DHCP IP address pool range to 192.168.1.100 to .150.
100Ft maybe too far for RBS distances. 40-maybe 60feet is a good recommended range.
- BmMdlkSep 13, 2022Tutor
