BmMdlk
Sep 12, 2022Tutor
No Valid IP address for multiple devices- comes and goes (RBR50 & 2 satellites)
This started a few months ago and has been getting progressively worse. Both wired and wireless devices randomly drop their connection with the error message no valid IP address. Power cycling the ro...
- Sep 13, 2022
Changing the address pool range seemed to fix things- at least for now, Thanks for that suggestion, I never would have thought of it!
I appreciate your help!
BmMdlk
Sep 13, 2022Tutor
Sep 15, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
