michael814's avatar
Jan 09, 2017
No way to disable 40mhz width on 2.4ghz?
I have a neighbor who is using 40mhz width on channel 3 (primary & guest SSIDs), which is occupying 2/3 of the band:     I know the correct solution here is to go talk to the neighbor and ask ...
