RonV42
Mar 03, 2018Luminary
None of my wired devices connect to RBS50 satellite
Today I was reworking my two satellite system and plugged in a camera and xbox into the Satellite and neither of them would connect. Also tried my laptop and a roku and nothing. I then tried my lap...
RonV42
Mar 04, 2018Luminary
Tried on both satellites neither will connect devices via ethernet ports. But wireless devices are definatly connected. I haven't used Beamforming for MIMO settings at all. I have been reading all the strange issues that people have been having with this firmware version and I may roll back and reconfigure. I hate it when a device has been working fine for almost a year and the vendor screws it up with a upgrade. I just wish there was a easy way to flag manual upgrades like my other hardware has.
Mar 04, 2018Guru - Experienced User
Check the ethernet cables as well to make sure they work. Swap out.
Let us know if downgrading helps.
- RonV42Mar 04, 2018Luminary
Well it took about two hours:
- shut down the two satellites
- factory reset the router
- telneted in and set autoupdate to no
- Backflashed the previous firmwar
- factory reset again
- telneted back in and found auto update to true reset it to falise
- Resetup my internet options
- Reconfigured the network DHCP devices etc.
- Factory reset one satellite
- Joined it to router over wifi
Tested with my laptop with ethernet cable and got a good DHCP address, also connected the second satellite and tested again with laptop and it connected fine. I can't believe that Netgear would allow these autoupdates to happen without understanding the impact to our routers.
