kywong's avatar
kywong
Not able to ping address
I connected my PC with cable to one of the ethernet ports on RBS50.  Everything works great.  However, I have problems pinging certain IP addresses in the local network but I can connect to them (eg ...
  • kywong's avatar
    kywong
    Apr 13, 2020
    I rebooted the entire system including the router and the problem goes away.  Thanks for your help.
