Anub
Aug 02, 2020Follower
Not able to set up the Orbi Router while having ATT Uverse Modem/Router
Hi , We got a Orbi AC3000 (RBK50-100NAS) today and we already have ATT Uverse Modem/Royter (5268AC FXN) at home. I would like to have a single Acess point preferrably the Orbi router. How do I ma...
Aug 02, 2020Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended.
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
Anub wrote:Hi ,
We got a Orbi AC3000 (RBK50-100NAS) today and we already have ATT Uverse Modem/Royter (5268AC FXN) at home. I would like to have a single Acess point preferrably the Orbi router. How do I make the connections in a simple way?
Also currently after setup when I try to login using the network SSID and password(available on the box), the password is not working. How can this be resolved.
Thanks
Anu B
