abduljm
Dec 16, 2017Follower
not accepting password
Network recently set up used to accept password from all computers and cell phones in the house. Now it no longer accepts the same password. Says that the WEP2 password. Resetting modem and router...
guzzijason
Dec 16, 2017Apprentice
Are you sure it says "WEP2"? The Orbi only supports WPA/WPA2.
If nothing else works, you can try resetting back to factory default settings and try setting up again as if it was new. Offhand, I'm not sure why things would suddently stop working at all.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
