Carolcarmike
May 08, 2019Aspirant
not accepting password
Setting up new or I and it will not accept my password in the settings!!! Support # !,!
schumaku
May 08, 2019Guru - Experienced User
Is this intended to be an "example" of the password syntax used?
Support # !,!
- CarolcarmikeMay 08, 2019Aspirant
Setting up new Orbi and it does not accept my password in the settings. Frustrated because I can not find a way to solve this issue. No support number to call. My orbi is registered and when I logged in, it accepted my password. Off to a frustrating start.
- FURRYe38May 08, 2019Guru - Experienced User
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in until the top led turns on AMBER then let go. Wait for the WHITE led to slowly pulsate, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
Thanks. I did write my password down immediately. Not sure what happened.
- schumakuMay 08, 2019Guru - Experienced User
Talking about the admin password (and a password you prefer) - or the wireless passphrase - how is it not accepted?
https://my.netgear.com/ ... within the 90 days you are eligible for various support variants, depending on the market/region/country.
Uahem ... did it, or what?
When
i go into my settings to put in the password for the Orbi. I put in my password and it does not accept it. When I logged in to Register my orbi I used this password.
