GSSS
May 24, 2019Aspirant
not accepting password
i am constantly being kick off the orbi network then need to rejoin. sometimes it accepts the password but usually it doesn’t -even when shared by another device that is connected. any ideas?
May 24, 2019Guru - Experienced User
What wireless device do you have that is experiencing this issue?
Have you forgotten the wireless profile ON this device, reboot then try to reconnect?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using?
Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings.
- GSSSMay 28, 2019Aspirant
Firmware 2.3.1.58
The Orbi is connected to a Hiton Router which is connected to an Aries modem M#TE502G
All devices ( iphones, ipads, TV, etc) seem to be affected from time to time. One minute they work great - the next minute the wireless drops out on one or two - although a connected device right next to one that drops out can be working fine. Then it asks for a password. Sometimes it will accept the password and sometimes it won't. The password has never changed. When another device (which is on the Orbi wireless) shares the password with the device that has been kicked out, it won't accept that either.
The satellites are less than 30 feet away from the router.
I am a neophyte here...How do I check and/or select what channel I am using?
There are few Wifi neighbors but none as strong as the Orbi.
How do i check the WPA security mode?
Were are the Beamforming and Mimo settings found ? On each device?
- FURRYe38May 28, 2019Guru - Experienced User
Since the Orbi is connected to a router up stream, is the Orbi in router or AP mode?
Is ALL other wifi on the other router fully turned OFF?
How / where do I check to see what mode the Orbi is in?
Yes, all other wifi in the upstrem router has been turned off
