Kingscoop
Aug 22, 2019Aspirant
Not all websites are loading
Some websites are not loading and some are with our laptops and phones. When going back and using the spectrum router, everything works fine.
Aug 22, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Kingscoop
I wired in directly to the modem by passing the bridge as stated and it didn't work. We couod get on the internet but not all websites would load.
- FURRYe38Aug 22, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem/router?
The ISP modem needs to be configured as suggested in options 1 or 2, , if not, try option #3 with the Orbi. A power cycle of the ISP modem and RBR OFF then back ON after 30 seconds maybe needed as well.
