Reynosa1984
Aug 03, 2019Aspirant
Not connecting to Circle
I just replaced a Orbi Router RBK53 with a new one RBK50 because it kept disconnecting from internet about twice a day.
I usually fixed it by reseting the modem so bouth a new one to see if there is teh modem that was bad.
Everything is working fine, except the Dysney Circle
I have enable it and set up the profiles but it does not actually seems to be filtering anything.
I tried to reset on teh app but it keeps telling me that that it is "Not Connected to Circle"
Need any advice you can provide.
Roberto
- ekhalilMasterWhere do you see “Not connected to Circle “?
Is Circle enabled under Parental Control in the web GUI or in the app?- Reynosa1984Aspirant
Yes. Circle is enabvled in the GUI. I also checked the app and it gives mne a choice to Disable Circle so it is enabled.
The "Cant connect to circle" appears when I press the "Reset" button on the APP.
- ekhalilMasterWhat does the Circle app say? Open the app go to the menu and select Manage. If Circle can or cannot see the Router it will be stated there.
What if you select one of the profiles in Circle and select History. Do you see any events there?
