Bambam5733
Apr 16, 2020Follower
Not connecting with honeywell
Having trouble connecting to my honeywell thermostat and energizer video door bell. How can I force orbi to connect to these via 2.4???
- Apr 16, 2020
If you provide the model number of these products, people can look up the specs. In general:
- Most products that SCREAM OUT "must have 2.4G" are simply stating the obvious, sort of like saying, "Car must have Gasoline."
If some person had a WiFi system that provided ONLY a 5G signal, then the product cannot connect because the product has only a (cheap) 2.4G radio in it. - Most products will simply install, especially cameras. With cameras, the smartphone setup process usually creates a SmartCode that the camera takes a picture of to set up the WiFi. The smart code includes the WiFi SSID and password. I have a whole box of different products that support only 2.4G and were installed using my Sony smartphone while it was connected to the Orbi at 5G.
- For those rare products that purchased their WiFi integration app from some company that didn't understand what they were doing, there is a very specific "work around":
- Go to the Orbi web access (http://orbilogin.net), Advanced Tab, Advanced Settings, Wireless and "uncheck" the box labelled "Broadcast SSID" for the 5G band and click "Apply". Every device that is currently connected to the Orbi at 5G will remain connected.
- Open the smartphone WiFi settings and "Forget" the Orbi WiFi.
- Re-open the smartphone WiFi settings, search for, and connect to the Orbi. Because Orbi is not broadcasting an SSID on 5g, the Orbi WiFi access point that the phone chooses will be on 2.4G.
- Use the app to set up the device.
- Once the device is working correctly, reverse these steps, i.e.
* Check "Broadcast SSID" and click "Apply"
* "Forget" the Orbi WiFi, then search and reconnect.
CrimpOn
Apr 16, 2020Guru - Experienced User
RBK123
Jul 19, 2022Aspirant
Latest solution to connect Honeywell Home Thermostat (Example: T6 Pro) to any of the single SSD band routers for example Orbi Mesh Wifi 6 router. Just disable the WAC settings in Honeywell Thermostat (Menu--> Wifi-->Press the right button->> once you see WAC settings select the option to disable and then follow steps in Resideo App to complete the steps to connect the device to Wifi, Configure and Register. No need to switch the WAC settings back to enable.
