baruamayukh54
Feb 01, 2021Aspirant
Not getting gigabit speed on wifi
My router's wifi doesn't support gigabit speed, neither through lan connection from router. If I connect my pc directly to the modem, it gives me proper speed but through router never received more t...
vajim
Feb 01, 2021Master
baruamayukh54 wrote:My router's wifi doesn't support gigabit speed, neither through lan connection from router. If I connect my pc directly to the modem, it gives me proper speed but through router never received more than 100 Mbps. Badly need a solution regarding this.
sounds like you need a new router
FYI....you'll never see what you pay for on WIFI
- baruamayukh54Feb 01, 2021AspirantMax speed I get through wifi is only 100Mbps. This is what bothering me.
- CrimpOnFeb 01, 2021Guru - Experienced User
Max speed I get through wifi is only 100Mbps. This is what bothering me.It will really help to know which device is being used, how speed is being tested, and what the Orbi reports about the device connection (is it 2.4G or 5G? what is the "link rate"?)
- FURRYe38Feb 01, 2021Guru - Experienced User
- vajimFeb 01, 2021Master
