tmbslce
Feb 03, 2021Aspirant
Not reaching full internet speed - RBR20
First post, so hopefully someone can help. I have recently moved into a smaller house. We had tech support help us set up the custom Orbi settings the first time around, but now we have moved, I ca...
Feb 03, 2021Guru - Experienced User
Most 5Ghz AC wifi devices will not ever see anything near 900Mpbs. Wired yes.
Due to hardward design and support, this limits the wifi connection speeds seen on 5Ghz AC. Most will max out at around 400-500Mpbs.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
tmbslce
When this was setup at my previous residence, it was reaching 700GB or so speed. Here I’m lucky if I get 200GB most of the time. It’s also unstable. Any recommendations to maximize whatever performance it can give?
- FURRYe38Feb 03, 2021Guru - Experienced User
What WiFi devices are you using to speed test with?
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
tmbslce wrote:
When this was setup at my previous residence, it was reaching 700GB or so speed. Here I’m lucky if I get 200GB most of the time. It’s also unstable. Any recommendations to maximize whatever performance it can give?- tmbslceFeb 03, 2021Aspirant
The ISP (Rogers) use the Gateway modem. I pulled the specs from my modem login:
System Hardware
Model:CGM4140COMVendor:TechnicolorHardware Revision:2.2Serial Number:2133060484112458Processor Speed:1503 MHzDRAM Total Memory:1024 MBDRAM Used Memory:638 MBDRAM Available Memory:386 MBFlash Total Memory:2048 MBFlash Used Memory:162 MBFlash Available Memory:1886 MB- vajimFeb 03, 2021Master
I believe your modem has a built in router already.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
