wrmann
Feb 02, 2022Tutor
Not trusted certificate issue
The message boards are not definitive on the issue I’m having, which is causing significant intermittent internet connection issues for multiple devices on my network. I attach a photo that shows w...
Feb 03, 2022Guru - Experienced User
NG deployes self asssigned certs for there routers. Something that may not be fully certified in other apps or devices. It's something that can be ignorned and shouldn't cause problems for email services. I would contact MS support for help and information regarding there product and configuration needed to ensure there products are working right.
https://community.netgear.com/t5/Orbi/Routerlogin-net-certificate-not-trusted/m-p/1988353#M104840
- wrmannFeb 03, 2022TutorI appreciate the response BUT this is an unsatisfying answer isn’t it?
It’s a little rich to suggest that Microsoft or Apple or Google (I’m running iOS and safari on mobile, windows and chrome on desktop) are the tail and Netgear is the dog - rather than the other way around.
Seems to me Netgear should step up and outline how their product (and device or computer or browser settings) needs to be configured to work on different common platforms - especially given that it seems to work better for me now with Access Control turned off. Please tell me if I’m wrong…- FURRYe38Feb 03, 2022Guru - Experienced User
Have you tried powering OFF the ISP modem AND RBR and devices for 1 minute then back ON with the modem, router then your devices?
Thanks again - yes I have tried that. And forgetting and re-adding network. And the other obvious hacks. It just keeps coming back. I also tried disabling private addressing on my phone to see if that helped but it didn't seem to.
Sure, I could pay for product support and then open a ticket. But does Netgear have a solution to the problem (that does not involve disabling features)? I am reluctant to pay for support if their solution is just going to be one of the following (which is all I see on the message board so far):
- this is someone else's problem
- just don't enable access control
- get a newer system from us
Etc., etc.
Thanks, I know this is a bit of a rant. But I just wish they were paying attention - at a minimum, this must impact thousands of customers as nothing about what I'm doing is particularly unique to me...
Something you can contact NG support about of course:
https://my.netgear.com/support/contact.aspx
Looks like for now, don't use Access Controls as others have found this resolves this.
