wrmann
Feb 02, 2022Tutor
Not trusted certificate issue
The message boards are not definitive on the issue I’m having, which is causing significant intermittent internet connection issues for multiple devices on my network. I attach a photo that shows w...
Feb 03, 2022Guru - Experienced User
NG deployes self asssigned certs for there routers. Something that may not be fully certified in other apps or devices. It's something that can be ignorned and shouldn't cause problems for email services. I would contact MS support for help and information regarding there product and configuration needed to ensure there products are working right.
https://community.netgear.com/t5/Orbi/Routerlogin-net-certificate-not-trusted/m-p/1988353#M104840
Something you can contact NG support about of course:
https://my.netgear.com/support/contact.aspx
Looks like for now, don't use Access Controls as others have found this resolves this.
