Tracytreit
Jun 09, 2019Aspirant
Nothing connects to my Orbi satellite
I was told to purchase this so everything wouldn’t be on the same router and my speed would be better. I have had it for 2 months and nothing connects to the satellite. The satellite is on a different...
Mooose
Jun 09, 2019Luminary
Could you try temporarily connecting an Ethernet cable for wired backhaul between the router and satellite to rule out connection issues between them?
Tracytreit
So I should bring the satellite to the main and connect with a cable. What do I do next to see if there is connection issues between them?
On my app,
I can see both the router and the satellite.
On my app,
- MoooseJun 09, 2019LuminaryWould it be possible to leave it where it is (or where you would prefer to have it) and use a long cable?
- TracytreitJun 09, 2019AspirantOk I will have to purchase one for that distance. After I get the cable and connect to the two ports what do I do?
- TracytreitJun 09, 2019AspirantOkay I found a cable. It said connection wired and then it showed 4 items connected to satellite. When i disconnect from cable it goes back to no connections on satellite
- MoooseJun 09, 2019LuminaryWith the wired connection, do you get speeds you are expecting from devices in the area serviced by the satellite?
Is it possible to route a cable permanently for wired backhaul? Even if you did have a decent wireless connection wired does have several advantages.
If you log into the web interface (likely 192.168.0.1 if you haven’t changed it) with the cable disconnected and navigate to the connected devices tab, what does it say in the Backhaul Status column for your satellite?
