Wizeguy123
Aug 14, 2024Aspirant
Novice - Setting up VPN on router - Orbi RBR50
I'm a novice at this, so any help would be appreciated. Goal: I want to disguise my IP address when streaming movies. I can easily do this for this my desktop or phone using the VPN in my Norto...
CrimpOn
Aug 14, 2024Guru - Experienced User
Alas, there are two parts to a Virtual Private Network (VPN)
- The VPN Host, which accepts connects from Clients and sets up an encrypted "tunnel" between them, which effectively shields traffic from inspection and hides the Client IP address.
- The VPN Client, many of which connect to a Host.
Netgear bundles OpenVPN Host software with Nighthawk and Orbi routers so that customers can connect to their home Local Area Network (LAN) when away. Netgear does not include a VPN Client capability with any of their home routers.
One solution would be to install a third party firmware which includes this capability. A programmer has written firmware for some Netgear systems, including the RBK50:
Another solution would be to install an appliance on the LAN which provides VPN Client capability, such as the GL-iNet
MT2500:
https://www.gl-inet.com/products/gl-mt2500/
or a similar product from Firewalla.
Perhaps I am mistaken..... How does "casting" video to televisions "work"? i.e.
- Does the user somehow bring up a menu on the device connected to the television and tell it which video to seek?
(In this case, it's pretty obvious that the source IP address will be the public IP of the customer router.) ... or - Does the user device "cast" the video stream fo the device, which passes it to the television.
(In that case, it would seem that installing a VPN on the user device would fulfill the requirement.)
Wizeguy123
My understanding of casting via chromecast is that when you cast a media stream, what you pass on to Chromecast is the data about the media source. Chromecast then streams the media directly from the source without passing through your desktop or phone. Therefore, the VPN on your desktop or phone will not shield the Chromecast IP address. Since the Chromecast is connected to my wifi, I assume the ip address will be mine.
- CrimpOnAug 14, 2024Guru - Experienced UserNot many options then. Sorry
