spd15ok
Oct 31, 2020Initiate
Now TV Router
I have had an Orbi system for a few years, but recently changed broadband provider to Now TV. They supply their own modem/WiFi router. There seems to be some compatibility issue between the Orbi rout...
Oct 31, 2020Guru - Experienced User
Easiest way?
put the orbi in access point mode.
you'd currently be in a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
There's 3 ways to fix it but simply putting the orbi in ap mode is probably the easiest.
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
That leaves the now tv router/gateway controlling the routing functions and the orbi running wifi/ethernet.
spd15ok
You beauty!
Thanks!
Simon
