goldnetN
Sep 29, 2018Aspirant
NowTV box problem with DM200/Orbi
Last week installed new Orbi wifi with DM200 modem (set to Modem only). Realised our NowTV (Roku) box stopped working with BBC iPlayer. Spent 2 hours trying to do factory reset on it - always fails w...
- Oct 07, 2018
Change the DM back to modem/router mode and configure the Orbi for AP mode. This will let the Orbi act as a wireless pass thru for any data. No routing involved in this mode.
Oct 07, 2018Guru - Experienced User
I would contact your service provider to see if Orbi is compatible with there services...
lwood1994 wrote:
im having this exact same issue with a netgear dm200 and a nighthawk x6.
lwood1994
Oct 07, 2018Aspirant
I’m not using orbi I’m using a nighthawk x6(r8000) Dm200 in brige mode and all the Plusnet details In the NETGEAR. Everything else works just now tv doesn’t. YouTube and all the other apps work just now tv. Something with the dm200 doesn’t let the now tv box or stick connect to its servers
- goldnetNOct 07, 2018Aspirant
Exactly - if I'm stuffed by the Orbi and you by the Nighthawk, it points to the DM200. As I said earlier, I bet there's an odd setting or protocol that could be adjusted if only someone here or at NG would accept it's a problem their end and not keep saying it's the other kit/apps...
- lwood1994Oct 07, 2018Aspirant
in thinking of replacing a dm200 with a vigor 130 ad reviews say it more reliable than the dm200
Hmm, I went for the DM200 because it was cheap (!) and also that NG couldn't claim any issues with its own Orbi kit (as there were a number of reports of issues with it).
I suppose I could return it (Amazon) but the Vigor 130 is over double the price...
And as I've said, I'm solving the problem by chucking NowTV. It's just taken too much time and effort to resolve. Netgear support is so painful...!
