goldnetN
Sep 29, 2018Aspirant
NowTV box problem with DM200/Orbi
Last week installed new Orbi wifi with DM200 modem (set to Modem only). Realised our NowTV (Roku) box stopped working with BBC iPlayer. Spent 2 hours trying to do factory reset on it - always fails w...
- Oct 07, 2018
Change the DM back to modem/router mode and configure the Orbi for AP mode. This will let the Orbi act as a wireless pass thru for any data. No routing involved in this mode.
goldnetN
Oct 07, 2018Aspirant
lwood1994 wrote:
im having this exact same issue on plusnet with a netgear dm200 and a nighthawk x6. now tv are saying that there seeing my internet speed as zero for some reason
Hi - so glad I'm not the only one!
Interesting you say your speed is showing as zero. I'm on Plusnet Super Fibre and getting around a 75 mbps connection.
The built-in speed test (in the mobile Orbi app or under QOS options in the web interface) won't work - reporting no or poor connection.
This is exactly the symptoms reported by the NowTV box when trying to reet, update or remove/add the iPlayer app.
Everything else on the wifi runs fast and fine, so I still think it's something within the NG setup that incorrectly reports connection speed/strength to the NowTV box.
Found tonight a response from NG support to my official support ticket (didn't know as there was no email notification). They ask about the back connection to the Orbi satellite (I assume they mean its IP) - nothing to do with the NowTV box as that sits 5 ft from the main router. Ask me to update firmware - reluctantly done and will recheck the NowTV box shortly.
I also posted a ticket under the DM200 but for some reason that's not registered under the same login and I don't know how to access it in the support system, nor a way to contact anyone to ask to merge the two logins. I can't register itunder the same ID as it says it's already registered!
lwood1994
if I go on speedtest.net I get 40 down and 10 up that is paid for . I don't get where now tv support got 0 from but that's what they told me. seems to me to be a fault with the dm200 maybe as that is the same unit in both our cases as your using a orbi router and I'm using a nighthawk x6 r8000
will be interesting what settings need to be changed to allow not tv services to connect to there system
