nugen
Sep 30, 2017Aspirant
Number of Daisy Chain satellites
With the new firmware update that enables satellites to dish chain. How many satellites are supported in a daisy chain on the RBK50 system. Also is it possible to convert a router to a satellite if...
aaz
Oct 01, 2017Virtuoso
It is not possible to run a router as an additional satallite - also let me warn you against running two orbi routers with 4 satellites on the same network - very bad idea that is.
I've seen someone from netgear say that you can easily run 3 satellites, not sure if more are supported but probably just slows the system down. Question is why would you need more? I have a 4500 sqft 3 story house and the RBK50 with two satellites has no problem covering the entire area and easily into my neighbors house across the yard.
- nugenOct 01, 2017AspirantIt's for long hallways and where there's much concrete.
