quietcore's avatar
quietcore
Follower
Feb 18, 2018
Nvidia Shield has extremely slow speeds with Orbi RBR50
I just set up my Orbi with one satellite to replace an old airport base station. The computer and iphone speeds all over my home are at least twice what I was getting before, however my Nvidia Shield which is connected to the Orbi with an ethernet cable is as slow as dial up. I have done speed tests on the Shield with google (both wired with ethernet and using wifi) and done the same speed tests on my phone and one laptop so far and the Shield is having major problems with speeds in kilobits not megabits, occasional buffering or drop outs occurred with the base station but I can't get anything to load for more than 10 seconds with Orbi. Any advice? Thanks in advance for any assistance.
Shield on ethernet 1.23mb down/219.4KB up
shield on wifi 280.4KB down/12.8KB up
laptop on wifi 224.6mb down/33.5mb up
iphone on wifi 202.6mb down/36.8mb up
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Since its just the shield have you tried anytype of factory reset on the shield?
    DarrenM
