hlk
Jul 15, 2020Aspirant
NVR to Orbi RBS50 satellite
Hi I have existing Hikvision NVR connected to my modem router (tplink archer d9) via Ethernet which is working fine. I also have orbi as router connected to the modem router and orbi satellite somewhe...
CrimpOn
Jul 15, 2020Guru - Experienced User
If both the TP-Link and the Orbi are "routers", then they are each creating separate IP subnets.
This often leads to devices being "unreachable."
When you plug the NVR into the Orbi satellite, it should request an IP address from the Orbi. This will be different from the IP address it was getting from the TP-Link.
What is the symptom of "not working"?
This "Double NAT condition" is usually handled by making one of the routers into "not a router".
In this situation, the easiest solution would be to put the Orbi into Access Point (AP) mode. That way, the TP-Link will give the NVR the same IP address it was getting before and all devices should be able to find it.
hlk
Thanks for your reply. I am not good at networking stuff but I think you might be right about setting one as AP mode. When I said it's not working I expect I can still access to my camera in NVR without changing anything. I shall give it a try and thanks again.
