devastata2121
Feb 11, 2021Follower
NVR to orbi satelite
Good evening,
Apologies if this is in the wrong section.
I have a new Hikvison NVR but cant run a cable to my virgin hub 3. Im looking at buying the Orbi RKB50 2 or 3 pack
Any help on how i would complete the setup and could i connect the NVR to the ethernet port in the orbi satellite. Do i get rid of the virgin hub 3 and use the orbi router and satellite. The satellite would be ujp stairs. do i just plug nvr in the ethernet port on the satellite
I have no clue on networking
Thank you in advance
1 Reply
Sort By
devastata2121 wrote:I have a new Hikvison NVR but cant run a cable to my virgin hub 3. Im looking at buying the Orbi RKB50 2 or 3 packAny help on how i would complete the setup and could i connect the NVR to the ethernet port in the orbi satellite. Do i get rid of the virgin hub 3 and use the orbi router and satellite. The satellite would be ujp stairs. do i just plug nvr in the ethernet port on the satelliteThere appear to be two issues:
- How to integrate Orbi WiFi with Virgin Media hub 3. I have no experience with that.
- How to connect an NVR to the network. Yes, connect an ethernet cable from the NVR to the Orbi satellite ethernet port.
