SLK-Purdue
Oct 22, 2021Luminary
NVRAM bug - FOUND IT!!
I have posted for some time about various issues with corrupt config parameters (NVRAM). If nothing else, I am a really stubborn geek with 50+ years of experience and I don't like unexplained failur...
CrimpOn
Oct 22, 2021Guru - Experienced User
Congratulations. My Orbi matches your exactly used plus free = 233,472. Looks like a classic case of using an 'int' where it should be a 'long int'.
Is this a V1 or V2 Orbi?
How many devices are represented in the Orbi tables (LAN reservation, previous but not connected, etc.?)
- SLK-PurdueOct 22, 2021Luminary
Tested on V1.
54 active connected devices and 56 items in the previous but not connected per WebUI.. Looks like there are 198 items in the NVRAM "access_control" table.
Scott
CrimpOn wrote:Congratulations. My Orbi matches your exactly used plus free = 233,472. Looks like a classic case of using an 'int' where it should be a 'long int'.
- CrimpOnOct 22, 2021Guru - Experienced User
My access_control list has 77 items in it. Looking at the Access Control web page
37 Active devices
36 Allowed but not connected
1 Blocked but not connected
74 Total. I think the missing 3 are three entries for ETH0. 74+3 = 77.
I would expect you to have 54+56+3 = 113, not 198.
I do not have Access Control enabled, so there is no particular difficulty in deleting "allowed but not connected' devices because they will simply authenticate the next time they show up. But, where did those extra 85 entries in your system come from?
My bad - access_control table has 105 entries. Counting error. I think that matches current totals as you did.
Thanks,
Scott
CrimpOn wrote:
SLK-Purdue wrote:54 active connected devices and 56 items in the previous but not connected per WebUI.. Looks like there are 198 items in the NVRAM "access_control" table.
37 Active devices
