SLK-Purdue
Oct 22, 2021Luminary
NVRAM bug - FOUND IT!!
I have posted for some time about various issues with corrupt config parameters (NVRAM). If nothing else, I am a really stubborn geek with 50+ years of experience and I don't like unexplained failur...
CrimpOn
Oct 22, 2021Guru - Experienced User
Congratulations. My Orbi matches your exactly used plus free = 233,472. Looks like a classic case of using an 'int' where it should be a 'long int'.
Is this a V1 or V2 Orbi?
How many devices are represented in the Orbi tables (LAN reservation, previous but not connected, etc.?)
SLK-Purdue
Tested on V1.
54 active connected devices and 56 items in the previous but not connected per WebUI.. Looks like there are 198 items in the NVRAM "access_control" table.
Scott
CrimpOn wrote:Congratulations. My Orbi matches your exactly used plus free = 233,472. Looks like a classic case of using an 'int' where it should be a 'long int'.
