SLK-Purdue
Oct 22, 2021Luminary
NVRAM bug - FOUND IT!!
I have posted for some time about various issues with corrupt config parameters (NVRAM). If nothing else, I am a really stubborn geek with 50+ years of experience and I don't like unexplained failur...
Oct 23, 2021Guru - Experienced User
Wondering if this issue is recent or how far it goes back in FW versions...
Wondering if also this is only or Orbi AC or does this effect more products globally.
SLK-Purdue
Oct 23, 2021Luminary
FURRYe38 wrote:Wondering if this issue is recent or how far it goes back in FW versions...
If this were part of the open source code, we would know. Sadly, it isn't
Since this is not something that would likely be introduced in an update, I would guess bases on experience that this is a day 1 bug.
Scott
- FURRYe38Oct 23, 2021Guru - Experienced User
Well maybe however the NVRAM and configuration section maybe something that is used across multiple product lines. Similar code base can be used across different products. Like the UI, basically the same format and feature listings, though some areas change per product lines. Hopefully this is only effected Orbi AC then.
Hopefully NG will take a look and get it corrected. Thanks for your deep dive man. Wish NG had you on as a dev. :smileywink:
- SLK-PurdueOct 23, 2021Luminary
FURRYe38 wrote:Well maybe however the NVRAM and configuration section maybe something that is used across multiple product lines. Similar code base can be used across different products. Like the UI, basically the same format and feature listings, though some areas change per product lines. Hopefully this is only effected Orbi AC then.
Been pretty clear that I am available and the price is right.
:smileywink:
