SJJ2021's avatar
SJJ2021
Follower
Sep 15, 2021
Obrbi Lbr20 using T mobile SIM card is throttled
Hoping someone can help me. I have an orbital Lbr20 with a SIM card plan with t mobile. The plan says no throttling and unlimited through Nomad Internet. With the SIM card activated, I had great internet speeds for the first 24 hours...speeds up to 50MB downloads. After 24 hours, I am getting throttled with speeds down to less than 1MB. Can't stream anything. Is there something I can adjust on my Orbi router? I hear that one can repair the IMEI number, but not sure what that means.
any advice would be appreciated.
Thx - SJJ
  • plemans's avatar
    You'd have to check with your isp.
    They are the ones that throttle speeds, not the router.
  • FURRYe38's avatar
    Please visit and post about this over in the Orbi LTE forum:
    https://community.netgear.com/t5/Orbi-LTE/bd-p/en-home-orbi-lte
    Thank you.
    Thx - SJJ
