jpbilderback
Mar 10, 2021Follower
Obri cbk752 - direct ethernet connection to satellite - SLOW - 10 mbps
S1arched But Couldn't Find Answer . Setup Orbi Cbk752 Yesterday. Works Except One Desktop Computer Is Direct Connected Via Ethernet To An Orbi Satellite And Seriously Is Getting Speeds Of 5 to 1...
Mar 10, 2021Guru - Experienced User
What is the brand and model# of the adapter in this pc?
Is it rated for 1000Mbps connection rate or less?
Be sure the adpaters dirvers are up to date.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Armor, and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
