ChargerMan426
Feb 20, 2019Tutor
Obri Fee
I just got off the phone with Orbi support because I can get my new outdoor unit to sync up (solid magenta no matter what i try) the tech support person said I had to pay them $100 or they will shut ...
CrimpOn
Feb 20, 2019Guru - Experienced User
That was a scam. Netgear will never "shut down your Orbi." If you search the forum, you will find numerous instances of people finding "Netgear Support" telephone numbers that are NOT Netgear.
- ChargerMan426Feb 20, 2019Tutor
I told them to let me talk to a manger and they said they would call me back. So the only info they have on me is a name, email, and phone number. Guess I'll make a new post on here to find some help with my RBS50Y issue.
- CrimpOnFeb 20, 2019Guru - Experienced User
Netgear provides 90 days of complimentary (free) support for products. You start the process at this web site: https://www.netgear.com/support/contact.aspx Notice that they expect you to register the product.
So I new they would charge for tech support but I had just bought this new satellite so one would assume that would get 90 days support right? The comment about them shutting down my network if I didnt pay was what sounded like a super scam.
- FURRYe38Feb 20, 2019Guru - Experienced User
You can always contact NG support or open a support ticket here:
https://www.netgear.com/mynetgear/registration/login.aspx
This is official NG support.
- michaelkenwardFeb 21, 2019Guru - Experienced User
Oh so true.
Netgear itself does not provide paid for support. It farms that out to GearHead Technical Support.
Any numbers found with a Google search are scams.
