ChargerMan426
Feb 20, 2019Tutor
Obri Fee
I just got off the phone with Orbi support because I can get my new outdoor unit to sync up (solid magenta no matter what i try) the tech support person said I had to pay them $100 or they will shut ...
CrimpOn
Feb 20, 2019Guru - Experienced User
That was a scam. Netgear will never "shut down your Orbi." If you search the forum, you will find numerous instances of people finding "Netgear Support" telephone numbers that are NOT Netgear.
ChargerMan426
Feb 20, 2019Tutor
I told them to let me talk to a manger and they said they would call me back. So the only info they have on me is a name, email, and phone number. Guess I'll make a new post on here to find some help with my RBS50Y issue.
- CrimpOnFeb 20, 2019Guru - Experienced User
Netgear provides 90 days of complimentary (free) support for products. You start the process at this web site: https://www.netgear.com/support/contact.aspx Notice that they expect you to register the product.
- ChargerMan426Feb 20, 2019Tutor
So I new they would charge for tech support but I had just bought this new satellite so one would assume that would get 90 days support right? The comment about them shutting down my network if I didnt pay was what sounded like a super scam.
- FURRYe38Feb 20, 2019Guru - Experienced User
Did you register thru that link? I woudn't imaging if you contacted someone thru that link that they would say that. IF they did, that would not be NG policy.
You can always contact NG support or open a support ticket here:
https://www.netgear.com/mynetgear/registration/login.aspx
This is official NG support.
