Timmeh1
Feb 24, 2019Aspirant
obri stopping ipad ios updates
Hello,
I have the Orbi RBR20 set up in my residence and since I've hooked everything up, my ipads and iphone will no longer do ios software updates. Suggestions?
I've got 5 devices and a...
Feb 24, 2019Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
Timmeh1 wrote:
Hello,
I've got 5 devices and all of them are doing the same thing thing. Saying Netgear orbi and all other items could not be downloaded.
- Timmeh1Feb 24, 2019Aspirant
Sorry, not sure what FW is/means
The Modem is a a Smart Rg - ( Primus is the service provider )
The orbi is pulled into my Smart RG modem and then im using orbi as my wifi in my house. Not sure if that is AP mode or operating in a Router system
- FURRYe38Feb 24, 2019Guru - Experienced User
FW = Firmware
Is there a model# on this ISP modem?
Possible this modem already has a built in router and WiFi which the Orbi does as well.
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem leaving it in router mode and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
model : Sr505n
