pugs
Dec 04, 2022Follower
obri voice rbs40v
I got new internet and am trying set up the orbi extender/smart speaker and I keep getting a message that it is not registered, but it is and it won't connect
KevinLiT
Dec 05, 2022NETGEAR Moderator
Hello pugs,
Welcome to the NETGEAR Community!
You are getting this message because your device is not registered with NETGEAR.
Please navigate to the link below for instructions on how to register your RBS40V:
How do I register a product on MyNETGEAR? | Answer | NETGEAR Support
Best,
Kevin
Community Team
CrimpOn
Dec 05, 2022Guru - Experienced User
This seems inconsistent with Post #1 where he says "but it is and it won't connect".
Also, I do not recall registering a product with Netgear being a requirement to connect it to a system.
The Orbi app, which is essential for activating the Alexa part of Orbi voice absolutely requires a Netgear account login.
Very confusing situation.
- KevinLiTDec 06, 2022NETGEAR Moderator
Hello Crimpon,
Thanks for your post!
Have you experienced this issue before?
Best,
Kevin
Community Team
- CrimpOnDec 06, 2022Guru - Experienced User
No. My two RBS40V's connected as satellites and both activated the "Voice" feature using the app.
Only one of the RBS40V's appears on my list of registered products. (must have overlooked registering one of the two. not much point in figuring out which since they are both out of warranty.).
Thus, my experience shows that registering an RBS40V is not a requirement for it to connect as a satellite, and also not a requirement for the Voice feature to be activated.
I am just terribly literal. The Original Poster (OP) said, " I keep getting a message that it is not registered, but it is and it won't connect". Is the OP incorrect (product is not actually registered)? Or, what does "won't connect" mean?
I should probably mention that I never use the Orbi app for anything important, like connecting a new satellite. However, the Voice settings can be done only on the Orbi app.
