evanwier
Aug 30, 2018Aspirant
Obscenely Slow Wi-Fi With RB50 on all devices.
Hi there... hoping to get some help with WiFi settings on my Orbi... I have spent months now playing with every setting possible and position around my house with absolutely no luck at all getting ...
Aug 30, 2018Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the IP modem the NG router is connected too?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
WMM should be enabled always.
You can leave beamforming enabled. If you don't have any MIMO devices, you can leave this disabled as well. Along with Daisy Chain and Fast Roaming...
Regarding Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
