evanwier
Aug 30, 2018Aspirant
Obscenely Slow Wi-Fi With RB50 on all devices.
Hi there... hoping to get some help with WiFi settings on my Orbi... I have spent months now playing with every setting possible and position around my house with absolutely no luck at all getting ...
evanwier
What FW is currently loaded?
What is the Mfr and model# of the IP modem the NG router is connected too?
Hitron CGNM-2250 - It is running in transparent bridge when I have the orbi connected, and I pull it from bridged via contacting the ISP when I need to test with it directly.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
About 15-20ft
I have tried 6, 11, and Auto for 2.4 and Every option, currently 48, for 5ghz. (Townhouse, so theres maybe 3 other wifi networks within range, nothing too horrible) As well, the Hitron works fine - I also spent the last 30 min keeping the Hitron in bridge mode, and re-installing my old Asus N66U - and with the Asus, again, I get full speeds, about 120-135 down on Wifi, unplug, plugin Orbi, immediately back in the 20s.
evanwier
FW is just windows - but it's disabled along with defender and smartscan during all testing with a group policy, I will enable it afterwards.
