Ron-orbi
May 17, 2020Aspirant
occassional bad wifi
Is there any way to know why sometimes my wifi is not so good? happens maybe 1% of the time is there a log I can access?
- May 25, 2020
Ron-orbi wrote:Do you know of other products to detect this?
There are plenty out there.
I'd start with a mobile phone. There is even a Netgear app (for Android at least). WiFi analytics.
Crude but a start.
michaelkenward
May 18, 2020Guru - Experienced User
Not in Orbi systems. And most logs have limited information gathering.
Perhaps you should investigate the possibility of local wifi interference. Are there any neighbours on the same wifi channels?
Ron-orbi
May 20, 2020Aspirant
I had not thought of that.
We live on 1 acre zoning - so houses are at least 100 feet awat
Based on advice from support, I just changed the 2.4GHZ channel from auto to 11
I don't even know if it uses 5GHZ or 2.4GHZ - do you know how I could tell which frequency was involved?
This problem only happens once in a great while.
